[QGIS-Developer] Popup window within Processing crashes QGIS
Nyall Dawson
nyall.dawson at gmail.com
Fri Aug 31 14:06:34 PDT 2018
On Fri, 31 Aug 2018 at 22:24, C Hamilton <adenaculture at gmail.com> wrote:
> Thanks Nyall!!! Unfortunately I was trying to make this a processing routine when I shouldn't have. It is good to know the boundaries. This function really requires user interactivity.
Mind sharing the general function of the plugin? There may still be a
way to make this work within Processing.
Regards,
Nyall
> Calvin
> On Thu, Aug 30, 2018 at 9:27 PM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
>> On Thu, 30 Aug 2018 at 23:38, C Hamilton <adenaculture at gmail.com> wrote:
>> > I have an algorithm that during execution gathers information from the data and then pops up a window for the user to select what the user would like to do.
>> > Is this possible in the Processing framework? I have tried doing this in processAlgorithm and it crashes QGIS. Here is how I call the popup window.
>> No - this is not supported and goes against the very fundamental
>> design of Processing. Argggh! ;)
>> But seriously, Processing was designed with the intention that all
>> user choices are made up-front. This allows algorithms to be nicely
>> executed inside of models, without the model halting mid-way waiting
>> for user input. It also allows algorithms, scripts, models, etc to be
>> run from headless environments such as console scripts.
>> In this case, you're getting a crash because you're trying to create
>> GUI components from your algorithm which is being executed in a
>> background thread. This is a big no-no in Qt land, and usually results
>> in a crash.
>> Nyall
>> > fieldsDialog = SelectionDialog(self.tableFeatures)
>> > fieldsDialog.exec_()
>> > items = fieldsDialog.selected
>> > Here is the beginning of the SelectionDialong class.
>> > class SelectionDialog(QDialog, FIELDS_CLASS):
>> > def __init__(self, feat, parent=None):
>> > super(SelectionDialog, self).__init__(parent)
>> > self.setupUi(self)
>> > Prior to Processing I passed in iface.mainWindow() as the parent. Is there a proper parent in Processing to pass? Perhaps this is the reason it is crashing.
>> > def __init__(self, iface, feat):
>> > super(SelectionDialog, self).__init__(iface.mainWindow())
>> > self.setupUi(self)
>> > Thanks,
>> > Calvin
