[QGIS-Developer] unable to build MacOS master (OpenCL)
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Mon Dec 3 00:42:59 PST 2018
Looks like 1.2 (compiled
https://github.com/yohanesgultom/parallel-programming-assignment/blob/master/PR2/opencl/device_query.c
Platform - 1
1.1 CL_PLATFORM_NAME: Apple
1.2 CL_PLATFORM_VENDOR: Apple
1.3 CL_PLATFORM_VERSION: OpenCL 1.2 (Oct 11 2018 21:04:03)
1.4 CL_PLATFORM_PROFILE: FULL_PROFILE
1.5 CL_PLATFORM_EXTENSIONS: cl_APPLE_SetMemObjectDestructor
cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names
cl_APPLE_gl_sharing cl_khr_gl_event
Device - 1:
CL_DEVICE_NAME: Intel(R) UHD Graphics 630
CL_DEVICE_VENDOR: Intel Inc.
CL_DRIVER_VERSION: 1.2(Oct 11 2018 20:55:51)
CL_DEVICE_VERSION: OpenCL 1.2
CL_DEVICE_MAX_COMPUTE_UNITS: 24
Device - 2:
CL_DEVICE_NAME: AMD Radeon Pro 560X Compute Engine
CL_DEVICE_VENDOR: AMD
CL_DRIVER_VERSION: 1.2 (Oct 16 2018 21:18:14)
CL_DEVICE_MAX_COMPUTE_UNITS: 16
On Mon, Dec 3, 2018 at 9:19 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> Hi Peter,
> the only change that come up to my mind is that we are now supporting also
> opencl versions > 1.1,
> can you please check what is the opencl version implemented on mac?
> It might be necessary to add a ifdef for mac to set
> #define CL_HPP_MINIMUM_OPENCL_VERSION 110
> #define CL_HPP_TARGET_OPENCL_VERSION 110
> #define CL_TARGET_OPENCL_VERSION 110
> as it was before the changes.
> On Mon, Dec 3, 2018 at 9:02 AM Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> wrote:
>> Hi,
>> I am unable to build QGIS master after Friday's changes in opencl header.
>> Any idea if I can still use official MACOS CL headers or how to proceed?
>> Thanks.
>> Peter
>> [ 19%] Building CXX object
>> src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometry.cpp.o
>> In file included from
>> /Users/peter/Projects/qgis1/QGIS/src/core/raster/qgshillshaderenderer.cpp:33:
>> /Users/peter/Projects/qgis1/QGIS/src/core/qgsopenclutils.h:25:
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1323:1:
>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_HOST_PROPERTIES'
>> CL_HPP_PARAM_NAME_INFO_2_0_(CL_HPP_DECLARE_PARAM_TRAITS_)
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1277:23:
>> note: expanded from macro 'CL_HPP_PARAM_NAME_INFO_2_0_'
>> F(cl_device_info, CL_DEVICE_QUEUE_ON_HOST_PROPERTIES,
>> cl_command_queue_properties) \
>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1278:23:
>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES,
>> 'CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1279:23:
>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1280:23:
>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_QUEUES'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1281:23:
>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_QUEUES, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_EVENTS'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1282:23:
>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_EVENTS, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_MAX_PIPE_ARGS'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1283:23:
>> F(cl_device_info, CL_DEVICE_MAX_PIPE_ARGS, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1284:23:
>> F(cl_device_info, CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_PACKET_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1285:23:
>> F(cl_device_info, CL_DEVICE_PIPE_MAX_PACKET_SIZE, cl_uint) \
>> error: use of undeclared identifier 'CL_DEVICE_SVM_CAPABILITIES'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1286:23:
>> F(cl_device_info, CL_DEVICE_SVM_CAPABILITIES,
>> cl_device_svm_capabilities) \
>> 'CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1287:23:
>> F(cl_device_info, CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT,
>> cl_uint) \
>> 'CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1288:23:
>> F(cl_device_info, CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT,
>> cl_uint) \
>> 'CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1289:23:
>> F(cl_device_info, CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT,
>> cl_uint) \
>> error: use of undeclared identifier 'CL_QUEUE_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1290:30:
>> F(cl_command_queue_info, CL_QUEUE_SIZE, cl_uint) \
>> error: use of undeclared identifier 'CL_MEM_USES_SVM_POINTER'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1291:20:
>> F(cl_mem_info, CL_MEM_USES_SVM_POINTER, cl_bool) \
>> 'CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1292:30:
>> F(cl_program_build_info, CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE,
>> size_type) \
>> error: use of undeclared identifier 'CL_PIPE_PACKET_SIZE'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1293:21:
>> F(cl_pipe_info, CL_PIPE_PACKET_SIZE, cl_uint) \
>> error: use of undeclared identifier 'CL_PIPE_MAX_PACKETS'
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1294:21:
>> F(cl_pipe_info, CL_PIPE_MAX_PACKETS, cl_uint)
>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:3293:16:
>> error: unknown type name 'cl_svm_mem_flags'; did you mean 'cl_mem_flags'?
>> static cl_svm_mem_flags getSVMMemFlags()
>> /System/Library/Frameworks/OpenCL.framework/Headers/cl.h:67:29: note:
>> 'cl_mem_flags' declared here
>> typedef cl_bitfield cl_mem_flags;
>> fatal error: too many errors emitted, stopping now [-ferror-limit=]
>> 20 errors generated.
>> make[2]: ***
>> [src/core/CMakeFiles/qgis_core.dir/raster/qgshillshaderenderer.cpp.o] Error
>> 1
>> make[2]: *** Waiting for unfinished jobs....
>> make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>> make: *** [all] Error 2
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/9818f2f0/attachment-0001.html>
