[QGIS-Developer] unable to build MacOS master (OpenCL)
Alessandro Pasotti
apasotti at gmail.com
Mon Dec 3 00:50:57 PST 2018
On Mon, Dec 3, 2018 at 9:43 AM Peter Petrik <
peter.petrik at lutraconsulting.co.uk> wrote:
> Looks like 1.2 (compiled
> https://github.com/yohanesgultom/parallel-programming-assignment/blob/master/PR2/opencl/device_query.c
So, please try to #ifdef for mac and set
#define CL_HPP_MINIMUM_OPENCL_VERSION 120
#define CL_HPP_TARGET_OPENCL_VERSION 120
#define CL_TARGET_OPENCL_VERSION 120
if that doesn't work, try with 110 instead of 120.
You can run an OpenCL smoke test by enabling it in the
options->acceleration and by using the hillshade renderer on a DEM raster
(also enable rendering debug log in options->rendering and you'll see in
the log is the hillshade is really using opencl).
Please let me know if this works for you.
> Platform - 1
> 1.1 CL_PLATFORM_NAME: Apple
> 1.2 CL_PLATFORM_VENDOR: Apple
> 1.3 CL_PLATFORM_VERSION: OpenCL 1.2 (Oct 11 2018 21:04:03)
> 1.4 CL_PLATFORM_PROFILE: FULL_PROFILE
> 1.5 CL_PLATFORM_EXTENSIONS: cl_APPLE_SetMemObjectDestructor
> cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names
> cl_APPLE_gl_sharing cl_khr_gl_event
> Device - 1:
> CL_DEVICE_NAME: Intel(R) UHD Graphics 630
> CL_DEVICE_VENDOR: Intel Inc.
> CL_DRIVER_VERSION: 1.2(Oct 11 2018 20:55:51)
> CL_DEVICE_VERSION: OpenCL 1.2
> CL_DEVICE_MAX_COMPUTE_UNITS: 24
> Device - 2:
> CL_DEVICE_NAME: AMD Radeon Pro 560X Compute Engine
> CL_DEVICE_VENDOR: AMD
> CL_DRIVER_VERSION: 1.2 (Oct 16 2018 21:18:14)
> CL_DEVICE_MAX_COMPUTE_UNITS: 16
> On Mon, Dec 3, 2018 at 9:19 AM Alessandro Pasotti <apasotti at gmail.com>
> wrote:
>> Hi Peter,
>> the only change that come up to my mind is that we are now supporting
>> also opencl versions > 1.1,
>> can you please check what is the opencl version implemented on mac?
>> It might be necessary to add a ifdef for mac to set
>> #define CL_HPP_MINIMUM_OPENCL_VERSION 110
>> #define CL_HPP_TARGET_OPENCL_VERSION 110
>> #define CL_TARGET_OPENCL_VERSION 110
>> as it was before the changes.
>> On Mon, Dec 3, 2018 at 9:02 AM Peter Petrik <
>>> Hi,
>>> I am unable to build QGIS master after Friday's changes in opencl
>>> header. Any idea if I can still use official MACOS CL headers or how to
>>> proceed?
>>> Thanks.
>>> Peter
>>> [ 19%] Building CXX object
>>> src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometry.cpp.o
>>> In file included from
>>> /Users/peter/Projects/qgis1/QGIS/src/core/raster/qgshillshaderenderer.cpp:33:
>>> /Users/peter/Projects/qgis1/QGIS/src/core/qgsopenclutils.h:25:
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1323:1:
>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_HOST_PROPERTIES'
>>> CL_HPP_PARAM_NAME_INFO_2_0_(CL_HPP_DECLARE_PARAM_TRAITS_)
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1277:23:
>>> note: expanded from macro 'CL_HPP_PARAM_NAME_INFO_2_0_'
>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_HOST_PROPERTIES,
>>> cl_command_queue_properties) \
>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1278:23:
>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES,
>>> 'CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1279:23:
>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE, cl_uint)
>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1280:23:
>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_QUEUES'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1281:23:
>>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_QUEUES, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_EVENTS'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1282:23:
>>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_EVENTS, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_MAX_PIPE_ARGS'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1283:23:
>>> F(cl_device_info, CL_DEVICE_MAX_PIPE_ARGS, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1284:23:
>>> F(cl_device_info, CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_PACKET_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1285:23:
>>> F(cl_device_info, CL_DEVICE_PIPE_MAX_PACKET_SIZE, cl_uint) \
>>> error: use of undeclared identifier 'CL_DEVICE_SVM_CAPABILITIES'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1286:23:
>>> F(cl_device_info, CL_DEVICE_SVM_CAPABILITIES,
>>> cl_device_svm_capabilities) \
>>> 'CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1287:23:
>>> F(cl_device_info, CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT,
>>> cl_uint) \
>>> 'CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1288:23:
>>> F(cl_device_info, CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT,
>>> cl_uint) \
>>> 'CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1289:23:
>>> F(cl_device_info, CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT,
>>> cl_uint) \
>>> error: use of undeclared identifier 'CL_QUEUE_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1290:30:
>>> F(cl_command_queue_info, CL_QUEUE_SIZE, cl_uint) \
>>> error: use of undeclared identifier 'CL_MEM_USES_SVM_POINTER'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1291:20:
>>> F(cl_mem_info, CL_MEM_USES_SVM_POINTER, cl_bool) \
>>> 'CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1292:30:
>>> F(cl_program_build_info,
>>> CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE, size_type) \
>>> error: use of undeclared identifier 'CL_PIPE_PACKET_SIZE'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1293:21:
>>> F(cl_pipe_info, CL_PIPE_PACKET_SIZE, cl_uint) \
>>> error: use of undeclared identifier 'CL_PIPE_MAX_PACKETS'
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1294:21:
>>> F(cl_pipe_info, CL_PIPE_MAX_PACKETS, cl_uint)
>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:3293:16:
>>> error: unknown type name 'cl_svm_mem_flags'; did you mean 'cl_mem_flags'?
>>> static cl_svm_mem_flags getSVMMemFlags()
>>> /System/Library/Frameworks/OpenCL.framework/Headers/cl.h:67:29: note:
>>> 'cl_mem_flags' declared here
>>> typedef cl_bitfield cl_mem_flags;
>>> fatal error: too many errors emitted, stopping now [-ferror-limit=]
>>> 20 errors generated.
>>> make[2]: ***
>>> [src/core/CMakeFiles/qgis_core.dir/raster/qgshillshaderenderer.cpp.o] Error
>>> 1
>>> make[2]: *** Waiting for unfinished jobs....
>>> make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>>> make: *** [all] Error 2
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alessandro Pasotti
>> w3: www.itopen.it
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/8090dff4/attachment-0001.html>
