[QGIS-Developer] unable to build MacOS master (OpenCL)
Peter Petrik
peter.petrik at lutraconsulting.co.uk
Mon Dec 3 01:22:25 PST 2018
Thanks, looks that it works with this patch, please see
https://github.com/qgis/QGIS/pull/8590
P.
On Mon, Dec 3, 2018 at 9:51 AM Alessandro Pasotti <apasotti at gmail.com>
wrote:
> On Mon, Dec 3, 2018 at 9:43 AM Peter Petrik <
> peter.petrik at lutraconsulting.co.uk> wrote:
>> Looks like 1.2 (compiled
>> https://github.com/yohanesgultom/parallel-programming-assignment/blob/master/PR2/opencl/device_query.c
> So, please try to #ifdef for mac and set
> #define CL_HPP_MINIMUM_OPENCL_VERSION 120
> #define CL_HPP_TARGET_OPENCL_VERSION 120
> #define CL_TARGET_OPENCL_VERSION 120
> if that doesn't work, try with 110 instead of 120.
> You can run an OpenCL smoke test by enabling it in the
> options->acceleration and by using the hillshade renderer on a DEM raster
> (also enable rendering debug log in options->rendering and you'll see in
> the log is the hillshade is really using opencl).
> Please let me know if this works for you.
>> Platform - 1
>> 1.1 CL_PLATFORM_NAME: Apple
>> 1.2 CL_PLATFORM_VENDOR: Apple
>> 1.3 CL_PLATFORM_VERSION: OpenCL 1.2 (Oct 11 2018 21:04:03)
>> 1.4 CL_PLATFORM_PROFILE: FULL_PROFILE
>> 1.5 CL_PLATFORM_EXTENSIONS: cl_APPLE_SetMemObjectDestructor
>> cl_APPLE_ContextLoggingFunctions cl_APPLE_clut cl_APPLE_query_kernel_names
>> cl_APPLE_gl_sharing cl_khr_gl_event
>> Device - 1:
>> CL_DEVICE_NAME: Intel(R) UHD Graphics 630
>> CL_DEVICE_VENDOR: Intel Inc.
>> CL_DRIVER_VERSION: 1.2(Oct 11 2018 20:55:51)
>> CL_DEVICE_VERSION: OpenCL 1.2
>> CL_DEVICE_MAX_COMPUTE_UNITS: 24
>> Device - 2:
>> CL_DEVICE_NAME: AMD Radeon Pro 560X Compute Engine
>> CL_DEVICE_VENDOR: AMD
>> CL_DRIVER_VERSION: 1.2 (Oct 16 2018 21:18:14)
>> CL_DEVICE_MAX_COMPUTE_UNITS: 16
>> On Mon, Dec 3, 2018 at 9:19 AM Alessandro Pasotti <apasotti at gmail.com>
>> wrote:
>>> Hi Peter,
>>> the only change that come up to my mind is that we are now supporting
>>> also opencl versions > 1.1,
>>> can you please check what is the opencl version implemented on mac?
>>> It might be necessary to add a ifdef for mac to set
>>> #define CL_HPP_MINIMUM_OPENCL_VERSION 110
>>> #define CL_HPP_TARGET_OPENCL_VERSION 110
>>> #define CL_TARGET_OPENCL_VERSION 110
>>> as it was before the changes.
>>> On Mon, Dec 3, 2018 at 9:02 AM Peter Petrik <
>>>> Hi,
>>>> I am unable to build QGIS master after Friday's changes in opencl
>>>> header. Any idea if I can still use official MACOS CL headers or how to
>>>> proceed?
>>>> Thanks.
>>>> Peter
>>>> [ 19%] Building CXX object
>>>> src/core/CMakeFiles/qgis_core.dir/geometry/qgsabstractgeometry.cpp.o
>>>> In file included from
>>>> /Users/peter/Projects/qgis1/QGIS/src/core/raster/qgshillshaderenderer.cpp:33:
>>>> /Users/peter/Projects/qgis1/QGIS/src/core/qgsopenclutils.h:25:
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1323:1:
>>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_HOST_PROPERTIES'
>>>> CL_HPP_PARAM_NAME_INFO_2_0_(CL_HPP_DECLARE_PARAM_TRAITS_)
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1277:23:
>>>> note: expanded from macro 'CL_HPP_PARAM_NAME_INFO_2_0_'
>>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_HOST_PROPERTIES,
>>>> cl_command_queue_properties) \
>>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1278:23:
>>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PROPERTIES,
>>>> 'CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1279:23:
>>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_PREFERRED_SIZE,
>>>> cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1280:23:
>>>> F(cl_device_info, CL_DEVICE_QUEUE_ON_DEVICE_MAX_SIZE, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_QUEUES'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1281:23:
>>>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_QUEUES, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_MAX_ON_DEVICE_EVENTS'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1282:23:
>>>> F(cl_device_info, CL_DEVICE_MAX_ON_DEVICE_EVENTS, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_MAX_PIPE_ARGS'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1283:23:
>>>> F(cl_device_info, CL_DEVICE_MAX_PIPE_ARGS, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1284:23:
>>>> F(cl_device_info, CL_DEVICE_PIPE_MAX_ACTIVE_RESERVATIONS, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_PIPE_MAX_PACKET_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1285:23:
>>>> F(cl_device_info, CL_DEVICE_PIPE_MAX_PACKET_SIZE, cl_uint) \
>>>> error: use of undeclared identifier 'CL_DEVICE_SVM_CAPABILITIES'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1286:23:
>>>> F(cl_device_info, CL_DEVICE_SVM_CAPABILITIES,
>>>> cl_device_svm_capabilities) \
>>>> 'CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1287:23:
>>>> F(cl_device_info, CL_DEVICE_PREFERRED_PLATFORM_ATOMIC_ALIGNMENT,
>>>> cl_uint) \
>>>> 'CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1288:23:
>>>> F(cl_device_info, CL_DEVICE_PREFERRED_GLOBAL_ATOMIC_ALIGNMENT,
>>>> cl_uint) \
>>>> 'CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1289:23:
>>>> F(cl_device_info, CL_DEVICE_PREFERRED_LOCAL_ATOMIC_ALIGNMENT,
>>>> cl_uint) \
>>>> error: use of undeclared identifier 'CL_QUEUE_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1290:30:
>>>> F(cl_command_queue_info, CL_QUEUE_SIZE, cl_uint) \
>>>> error: use of undeclared identifier 'CL_MEM_USES_SVM_POINTER'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1291:20:
>>>> F(cl_mem_info, CL_MEM_USES_SVM_POINTER, cl_bool) \
>>>> 'CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1292:30:
>>>> F(cl_program_build_info,
>>>> CL_PROGRAM_BUILD_GLOBAL_VARIABLE_TOTAL_SIZE, size_type) \
>>>> error: use of undeclared identifier 'CL_PIPE_PACKET_SIZE'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1293:21:
>>>> F(cl_pipe_info, CL_PIPE_PACKET_SIZE, cl_uint) \
>>>> error: use of undeclared identifier 'CL_PIPE_MAX_PACKETS'
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:1294:21:
>>>> F(cl_pipe_info, CL_PIPE_MAX_PACKETS, cl_uint)
>>>> /Users/peter/Projects/qgis1/QGIS/external/opencl-clhpp/include/CL/cl2.hpp:3293:16:
>>>> error: unknown type name 'cl_svm_mem_flags'; did you mean 'cl_mem_flags'?
>>>> static cl_svm_mem_flags getSVMMemFlags()
>>>> /System/Library/Frameworks/OpenCL.framework/Headers/cl.h:67:29: note:
>>>> 'cl_mem_flags' declared here
>>>> typedef cl_bitfield cl_mem_flags;
>>>> fatal error: too many errors emitted, stopping now [-ferror-limit=]
>>>> 20 errors generated.
>>>> make[2]: ***
>>>> [src/core/CMakeFiles/qgis_core.dir/raster/qgshillshaderenderer.cpp.o] Error
>>>> 1
>>>> make[2]: *** Waiting for unfinished jobs....
>>>> make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>>>> make: *** [all] Error 2
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Alessandro Pasotti
>>> w3: www.itopen.it
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/db4cc332/attachment-0001.html>
