[QGIS-Developer] [Qgis-user] Mac OS packages ...again!
Tim Sutton tim at kartoza.com
Mon Dec 3 10:29:33 PST 2018
Hi
> On 03 Dec 2018, at 09:32, Peter Petrik <peter.petrik at lutraconsulting.co.uk> wrote:
> Hi,
> Python is already bundled in our package. The package is really standalone, so you do not need to have anything else installed. The note about Python is that, unfortunately, the python distribution we use ATM is not compatible with MacOS 10.11 and 10.12. One way how to fix it is probably use Python official distribution and not Homebrew distribution in the process of creation of our package.
Ah ok cool thanks for the clarification. I can confirm that the package I downloaded last night picks up the python interpreter inside the bundle nicely:
import sys
for p in sys.path:
	print(p)
/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/karika
/Applications/QGIS3.4.2.app/Contents/MacOS/../Resources/python
/Applications/QGIS3.4.2.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
/Applications/QGIS3.4.2.app/Contents/Resources/python
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages
What is the recommended way to install additional deps (e.g. via pip) into the bundled python environment? If we try to just directly  use the python interpreter (see below) it does not have the correct python path:
[timlinux at sandstone /Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/3.7/bin]$ ./python3.7
Python 2.7.10 (default, Aug 17 2018, 17:41:52)
[GCC 4.2.1 Compatible Apple LLVM 10.0.0 (clang-1000.0.42)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> for p in sys.path:
...     print(p)
/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7
/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/site-packages
/Library/Python/2.7/site-packages/numpy-override
/Library/Python/2.7/site-packages/matplotlib-override
/Library/Frameworks/GDAL.framework/Versions/2.1/Python/2.7/site-packages
/Library/Python/2.7/site-packages/pip-9.0.1-py2.7.egg
/Library/Python/2.7/site-packages/pycharm-debug.egg
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload
/Users/timlinux/Library/Python/2.7/lib/python/site-packages
/usr/local/lib/python2.7/site-packages
/usr/local/lib/python2.7/site-packages/pycharm-debug.egg
/usr/local/lib/python2.7/site-packages/geos
/usr/local/Cellar/numpy/1.15.3/libexec/nose/lib/python2.7/site-packages
/usr/local/lib/python2.7/site-packages/wx-3.0-osx_cocoa
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC
KeyboardInterrupt
>>> quit()
Maybe we need to bundle in pip and a tool from within QGIS to call pip (some examples were given on this mailing list in the past) from within QGIS so that the python interpreter has the correct context….this would probably be useful for windows users too?
Regards
Tim
> P.
> On Sun, Dec 2, 2018 at 10:16 PM Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> wrote:
> Hi
>> On 30 Nov 2018, at 16:28, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk <mailto:saber.razmjooei at lutraconsulting.co.uk>> wrote:
>> Hi Tim and all,
>> We have managed to package QGIS with version number. So, you can have all versions of QGIS installed side-by-side:
>> https://lutraconsulting.github.io/qgis-mac-packager/ <https://lutraconsulting.github.io/qgis-mac-packager/>
>> (master build is in progress and should be ready in an hour or so).
> This is great, grabbing it now!
>> Feel free to test and file tickets.
> Cool, will do.
> @Peter can you clarify what you meant by your reply regarding python? Are you suggesting I need to install the python.org <http://python.org/> package too? Do you have plans to bundle python into your QGIS.app?
> Regards
> Tim
>> Regards
>> Saber
>> On Wed, 21 Nov 2018 at 15:42, Peter Petrik <peter.petrik at lutraconsulting.co.uk <mailto:peter.petrik at lutraconsulting.co.uk>> wrote:
>> Python is taken directly from homebrew bottle. Worth try with the python.org <http://python.org/> package.
>> P.
>> On Wed, Nov 21, 2018 at 3:23 PM William Kyngesburye <woklist at kyngchaos.com <mailto:woklist at kyngchaos.com>> wrote:
>> Are you building Python from source?  I use the python.org <http://python.org/> binary distribution and have no problems running QGIS 3 on Sierra.  That means they are probably building with an older SDK so those new symbols are not used.
>>> On Nov 21, 2018, at 3:38 AM, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk <mailto:saber.razmjooei at lutraconsulting.co.uk>> wrote:
>>> Hi Tim,
>>> Yes, it should work with 10.13 and 10.14. But for older versions there is an upstream blocker which we will look into later:
>>> https://github.com/lutraconsulting/qgis-mac-packager/issues/22 <https://github.com/lutraconsulting/qgis-mac-packager/issues/22>
>>> Regards
>>> Saber
>>> On Wed, 21 Nov 2018 at 09:36, Tim Sutton <tim at kartoza.com <mailto:tim at kartoza.com>> wrote:
>>> Nice going! I will test them out for you! Did you manage to fix the python path issue?
>>> Regards
>>> Tim
>>>> On 21 Nov 2018, at 11:15, Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk <mailto:saber.razmjooei at lutraconsulting.co.uk>> wrote:
>>>> Dear all,
>>>> We managed finally to set up an integrated infrastructure to automatically create the following packages for QGIS:
>>>> 1- QGIS current release (3.4.1): you will get the new packages (e.g. 3.4.2) on the same day as point release
>>>> 2- QGIS nightly: generates a new package every day from the master branch with all the latest features (and bugs!). This is not currently available from the official QGIS download page.
>>>> The packages are all signed and you don't need to circumvent any security to be able to install them. Everything should work for 10.13 and 10.14 but with older versions of Mac OS, you may have some issues with Python and plugins (see: https://github.com/lutraconsulting/qgis-mac-packager/issues <https://github.com/lutraconsulting/qgis-mac-packager/issues>).
>>>> We will appreciate if you test and report back any problem.
>>>> Kind regards
>>>> Saber
>>>> Saber Razmjooei
>>>> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>>> Tim Sutton
>>> Co-founder: Kartoza
>>> Ex Project chair: QGIS.org <http://qgis.org/>
>>> Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
>>> Desktop GIS programming services
>>> Geospatial web development
>>> GIS Training
>>> Consulting Services
>>> Skype: timlinux
>>> IRC: timlinux on #qgis at freenode.net <http://freenode.net/>
>>> Saber Razmjooei
>>> +44 (0)7568 129733
>>> <KartozaNewLogoThumbnail.jpg><KartozaNewLogoThumbnail.jpg>_______________________________________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/ <http://www.kyngchaos.com/>
>> Earth: "Mostly harmless"
>> - revised entry in the HitchHiker's Guide to the Galaxy
>> Saber Razmjooei
>> +44 (0)7568 129733 <tel:+44%207568%20129733>
> Tim Sutton
> Co-founder: Kartoza
> GIS Training
> Consulting Services
> Skype: timlinux
Tim Sutton
Co-founder: Kartoza
GIS Training
Consulting Services
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/1cac3f25/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/1cac3f25/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
