[QGIS-Developer] [Qgis-user] Mac OS packages ...again!
Tim Sutton tim at kartoza.com
Mon Dec 3 10:39:43 PST 2018
On 03 Dec 2018, at 20:29, Tim Sutton <tim at kartoza.com> wrote:
Hi
> On 03 Dec 2018, at 09:32, Peter Petrik <peter.petrik at lutraconsulting.co.uk <mailto:peter.petrik at lutraconsulting.co.uk>> wrote:
> Hi,
> Python is already bundled in our package. The package is really standalone, so you do not need to have anything else installed. The note about Python is that, unfortunately, the python distribution we use ATM is not compatible with MacOS 10.11 and 10.12. One way how to fix it is probably use Python official distribution and not Homebrew distribution in the process of creation of our package.
Ah ok cool thanks for the clarification. I can confirm that the package I downloaded last night picks up the python interpreter inside the bundle nicely:
import sys
for p in sys.path:
	print(p)
/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/karika
/Applications/QGIS3.4.2.app/Contents/MacOS/../Resources/python
/Applications/QGIS3.4.2.app/Contents/MacOS/../Resources/python/plugins
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python37.zip
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/lib-dynload
/Applications/QGIS3.4.2.app/Contents/Resources/python
/Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/Current/lib/python3.7/site-packages
What is the recommended way to install additional deps (e.g. via pip) into the bundled python environment? If we try to just directly  use the python interpreter (see below) it does not have the correct python path:
[timlinux at sandstone /Applications/QGIS3.4.2.app/Contents/Frameworks/Python.framework/Versions/3.7/bin]$ ./python3.7
Python 2.7.10 (default, Aug 17 2018, 17:41:52)
[GCC 4.2.1 Compatible Apple LLVM 10.0.0 (clang-1000.0.42)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> for p in sys.path:
...     print(p)
/Library/Frameworks/SQLite3.framework/Versions/C/Python/2.7
/Library/Frameworks/GEOS.framework/Versions/3/Python/2.7/site-packages
/Library/Python/2.7/site-packages/numpy-override
/Library/Python/2.7/site-packages/matplotlib-override
/Library/Frameworks/GDAL.framework/Versions/2.1/Python/2.7/site-packages
/Library/Python/2.7/site-packages/pip-9.0.1-py2.7.egg
/Library/Python/2.7/site-packages/pycharm-debug.egg
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old
/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload
/Users/timlinux/Library/Python/2.7/lib/python/site-packages
/usr/local/lib/python2.7/site-packages
/usr/local/lib/python2.7/site-packages/pycharm-debug.egg
/usr/local/lib/python2.7/site-packages/geos
/usr/local/Cellar/numpy/1.15.3/libexec/nose/lib/python2.7/site-packages
/usr/local/lib/python2.7/site-packages/wx-3.0-osx_cocoa
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python
/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC
KeyboardInterrupt
>>> quit()
Maybe we need to bundle in pip and a tool from within QGIS to call pip (some examples were given on this mailing list in the past) from within QGIS so that the python interpreter has the correct context….this would probably be useful for windows users too?
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/7be9a4b2/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181203/7be9a4b2/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
