[QGIS-Developer] Whatever is wrong with QGIS 3.x SQL server	driver
    Nyall Dawson
    nyall.dawson at gmail.com
    Thu Dec  6 01:17:29 PST 2018
On Thu, 6 Dec 2018 at 19:05, Bo Victor Thomsen
<bo.victor.thomsen at gmail.com> wrote:
> Hi list -
> I've done some experiments with a dataset consisting of 440000 rows and uploaded this to two database servers: Postgres and SQLServer. Both tables has indexes on Primary key and the spatial column.
> And then connected to both tables in QGIS. The SQL server is 3 times slower in retrieving the dataset than Postgres in QGIS!
It's probably the extra validity checks which were added. SQL Server
itself is broken by design when it comes to spatial data handling and
if it encounters an invalid geometry it will silently abort the
request and you'll be missing features from the layer. But there's *no
way* for QGIS to detect when this occurs! Accordingly QGIS takes the
"safer is better" approach and forces a validity check and make valid
step as part of the queries sent to SQL Server. This avoids the
potentially missing features, but comes at a large cost.
If you're 100% sure that your tables have no invalid geometries (and
never will have any!), you *can* switch this check off. But be
warned... if you ever introduce invalid geometries into your tables,
you'll get data loss. The setting is under the SQL Server connection's
properties -- "skip invalid geometry handling".
Let me know if this helps at all
Nyall
