[QGIS-Developer] Whatever is wrong with QGIS 3.x SQL server driver
Bo Victor Thomsen
bo.victor.thomsen at gmail.com
Thu Dec 6 02:05:16 PST 2018
Hi Nyall -
Thanks for taking your time answering me :-)
I've tried switching the validity check off as described. As far as I can
measure, there is no time difference with or without the validity check.
When does the validity check kick in? Writing or reading the features? Or
both?
And the validity check doesn't explain the obvious time difference between
the OGR driver and the native QGIS driver for SQL Server
However, I *will* use your explanation about SQL Server's behavior
regarding invalid geometries as an argument for my customers to switch to
Postgres instead of using SQLServer :-)
Den tor. 6. dec. 2018 kl. 10.17 skrev Nyall Dawson <nyall.dawson at gmail.com>:
> On Thu, 6 Dec 2018 at 19:05, Bo Victor Thomsen
> <bo.victor.thomsen at gmail.com> wrote:
> > Hi list -
> > I've done some experiments with a dataset consisting of 440000 rows and
> uploaded this to two database servers: Postgres and SQLServer. Both tables
> has indexes on Primary key and the spatial column.
> > And then connected to both tables in QGIS. The SQL server is 3 times
> slower in retrieving the dataset than Postgres in QGIS!
> It's probably the extra validity checks which were added. SQL Server
> itself is broken by design when it comes to spatial data handling and
> if it encounters an invalid geometry it will silently abort the
> request and you'll be missing features from the layer. But there's *no
> way* for QGIS to detect when this occurs! Accordingly QGIS takes the
> "safer is better" approach and forces a validity check and make valid
> step as part of the queries sent to SQL Server. This avoids the
> potentially missing features, but comes at a large cost.
> If you're 100% sure that your tables have no invalid geometries (and
> never will have any!), you *can* switch this check off. But be
> warned... if you ever introduce invalid geometries into your tables,
> you'll get data loss. The setting is under the SQL Server connection's
> properties -- "skip invalid geometry handling".
> Let me know if this helps at all
> Nyall
Med venlig hilsen
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181206/d04b172e/attachment.html>
