[QGIS-Developer] Any ways to avoid offsets being shown in printed map legend?
magerlin MAP at ramboll.dk
Mon Dec 17 10:59:37 PST 2018
When mapping things like bus routes it can be handy to offset routes if more
than one route uses the same road.
But I see no way to avoid the offsets also being shown in the legend off
"printed" maps (or created pdf's, png's etc).
I have just had a case, where my client says "you need to clean up those
miss-alignments in the map-legend".
I can get almost there if I hardcode the offset using "data defined
override", but this solution only corrects the Layers panel and the "Legend
panel" in print composer - It has no effect on the legend in the print
composer canvas and final printed map...
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
