[QGIS-Developer] Marker line y offset
    magerlin
    MAP at ramboll.dk
    Tue Dec 18 00:58:51 PST 2018
Really fun stuff arises when you then use the arrows to increase width (in
steps of 0.2 *mm*)
Explaining somebody why you are using a linewidth of 0.46 mm, well eh....
you know:
1/10th of an inch + 0.2 mm isn't that a natural width to choose :-)
The used increments of 0.20 mm indicates by the way, that default width
should be 0.20 mm and not 0.25 mm to give nicer looking values when
incrementing like 1,0 mm and not 1.05 mm.
Regards Morten
Currently using Qgis 2.18.23 (OSGeo4) and Qgis 3.4.2 in parallel
Windows 7, 64bit
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
