[QGIS-Developer] Keeping OTB algorithm in qgis processing
Werner Macho werner.macho at gmail.com
Thu Feb 1 00:39:06 PST 2018
Hi all,
I am also in favour of removing all the work that is not directly related
to QGIS.
But I'd also like to ask if there is already a plugin available (on
github?) that for e.g. readds the GRASS functionality?
Furthermore I'd like to know if it is possible to create a plugin for
official stable GRASS and GRASS development version, which in the best case
can be installed side by side?
(Same applies to SAGA and all the other providers).
I am sure there is a huge possibility that an ecosystem will be created
around those kind of plugins.
kind regards
Werner
On Thu, Feb 1, 2018 at 9:33 AM, G. Allegri <giohappy at gmail.com> wrote:
> +1 also from me to the removal of the providers from core. IMHO I would
> also remove GRASS, but I understand it could be a tough decision.
> The provider system + plugin architecture provide all the means to keep
> them separate from the core.
> We all agree, I guess, that less is better then more, to guarantee the
> highest quality we can afford.
> Giovanni
> Il 1 feb 2018 09:23, "Paolo Cavallini" <cavallini at faunalia.it> ha scritto:
>> Hi Rashad,
>> Il 31/01/2018 10:43, Rashad Kanavath ha scritto:
>> > What I can propose is to lower the burden on maintenance but the code
>> > should be put back to qgis if possible.
>> > So qgis can focus on issue related only to that and after a while things
>> > will stabilize.
>> > Indeed, if there is something broken in this algo otb team will help
>> fix it.
>> thanks for your offer, much appreciated. Would this include also the
>> inclusion of OTB in the standalone installers for Windows? It would be
>> good to make sure we always have the most appropriate version, both for
>> 32 and 64 bit.
>> All the best.
>> Paolo Cavallini - www.faunalia.eu
>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180201/f921600d/attachment-0001.html>
More information about the QGIS-Developer mailing list
