[QGIS-Developer] External providers in QGIS
Victor Olaya
volayaf at gmail.com
Wed Feb 7 02:18:45 PST 2018
I dont see the advantage in having providers in core. And if there is an
advantage, it's clearly not in how easy it is going to be to maintain the
plugin. If the people responsible of a given backend (like OTB) are going
to maintain it (which makes sense), why putting it in core where they don't
have write access? Better in a separate repo. Also, they can release
whenever there are changes, without having to wait for a new release. That
way, the plugin will always be in sync with new releases of the backend app.
If we put them in core...why putting only this big ones (which in some
cases require installing external apps manually by the user), and not put
other plugins that exist and contain Processing providers?
I thought the idea was to not have core plugins and avoid them if possible.
I don't see why we have to treat plugins that have Processing provider in a
different way. Specially considering how easy it is to install a plugin in
QGIS.
Cheers
2018-02-06 18:57 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
> Hi all,
> following the discussion on qgis-dev ML:
> https://lists.osgeo.org/pipermail/qgis-developer/2018-January/051701.html
> it has been proposed to remove all external providers (namely OTB,
> already removed, GRASS, and SAGA) from Processing in QGIS2 (GDAL will
> remain as QGIS cannot be built without). This raised a number of
> concerns, so PSC decided not to rush removing them from the upcoming 3.0
> release, and to open a wider discussions about this, involving all the
> interested parties, to find an optimal solution.
> If volunteers outside QGIS core team, ideally from the respective
> backends, could take the maintenance of these providers, not much would
> change for the end user. If not, this will mean effectively missing
> hundreds of algs from QGIS.
> I personally propose to reinstate the OTB plugin with Rashad (from OTB)
> as maintainer.
> QGIS.ORG will seek to support any decision made with funding where
> possible.
> Looking forward for your feedback.
> All the best.
> Paolo Cavallini - www.faunalia.eu
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180207/0ff2fe30/attachment.html>
