[QGIS-Developer] SSL cert problem WIndows: OGR or osgeo certificate install issue?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Feb 8 05:53:56 PST 2018
Hi Richard,
(good test!)
I've tested on Windows 10 through OGR using MS4W 3.2.3, which includes
the latest ca-cert bundle, and an updated libcurl, here are the results:
(note that by running the command "setenv.bat" it automagically sets the
CURL_CA_BUNDLE variable)
https://gist.github.com/jmckenna/1d4d2c741236f44cc91299dd487fb647
Thanks for sharing this test.
(latest MS4W: http://ms4w.com )
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2018-02-08 6:52 AM, Richard Duivenvoorde wrote:
> Can I pull some attention to:
> https://issues.qgis.org/issues/17947
> On windows it is not possible (both 2.18 and master) to pull a geojson
> via https into QGIS.
> Given REST interfaces becoming more and more popular I think this is an
> important issue.
> But I'm not sure if it is a OGR problem (given ogrinfo <httpsurl> also
> fails), or it is a local windows certificate problem.
> There is no problem on Linux here with me.
> Tried to start a fresh config too.
> Can windows people confirm if
> https://duif.net/Testing_QGIS1.geojson
> fails? While
> http://duif.net/Testing_QGIS1.geojson
> is ok?
> Regards,
> Richard
