[QGIS-Developer] Processing Help system
Alexandre Neto
senhor.neto at gmail.com
Fri Feb 9 02:55:43 PST 2018
>From what I understand, we should stick to the algorithm ID. The provider
is already implicit by the file structure. Assuming that that ID is unique
across all the providers.
processing_algs > qgis > vector analysis tools
matteo <matteo.ghetta at gmail.com> escreveu no dia sexta, 9/02/2018 às 10:44:
> Hi Alexandre,
> > We don't need to change the algorithms titles, we just need to add an
> extra
> > anchor with the algorithm ID before it:
> > .. _nearestneighbouranalysis:
> > Nearest neighbour analysis
> > Description
> > <put algorithm description here>
> thanks for the hint.
> I've already put anchors before each algorithm, but with the provider name:
> .. _qgis_nearestneighbouranalysis:
> so I can get rid of the provider name and it should work correctly?
> Thanks
> Matteo
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180209/e90edee1/attachment.html>
