[QGIS-Developer] Processing Help system
Richard Duivenvoorde rdmailings at duif.net
Fri Feb 9 03:10:18 PST 2018
I thought wat Alexandre was saying was ok, but trying it out, it seems
just to create a 'span' with that id not a href#anchor ...
Anybody else can try?
Richard
On 09-02-18 11:55, Alexandre Neto wrote:
> From what I understand, we should stick to the algorithm ID. The
> provider is already implicit by the file structure. Assuming that that
> ID is unique across all the providers.
> processing_algs > qgis > vector analysis tools
> matteo <matteo.ghetta at gmail.com <mailto:matteo.ghetta at gmail.com>>
> escreveu no dia sexta, 9/02/2018 às 10:44:
>     Hi Alexandre,
>     > We don't need to change the algorithms titles, we just need to add
>     an extra
>     > anchor with the algorithm ID before it:
>     > .. _nearestneighbouranalysis:
>     > Nearest neighbour analysis
>     > Description
>     > <put algorithm description here>
>     thanks for the hint.
>     I've already put anchors before each algorithm, but with the
>     provider name:
>     .. _qgis_nearestneighbouranalysis:
>     so I can get rid of the provider name and it should work correctly?
>     Thanks
>     Matteo
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
More information about the QGIS-Developer mailing list
