[QGIS-Developer] Processing Help system
Alexandre Neto
senhor.neto at gmail.com
Fri Feb 9 04:20:33 PST 2018
So, is it settled for Processing algorithms help? If so, we should
celebrate!!
Then, we need to think about the rest of the help system :D
DelazJ <delazj at gmail.com> escreveu no dia sexta, 9/02/2018 às 12:04:
> Actually, name() does not contain spacing and I think displayName is
> translated. So should not work as is
> 2018-02-09 13:01 GMT+01:00 DelazJ <delazj at gmail.com>:
>> Hi,
>> Maybe we can also fix this issue on the application side: in docs, we try
>> to give the section title the same name as the alg ie the way it's shown to
>> user (eg "hypsometric curves"). What Sphinx does is to concatenate it with
>> hyphen when building the url. How about doing this concatenation in helpUrl
>> function? this way, link from QGIS will already be
>> "helpId/groupID/algnameconcatenatedbyhyphen" --> same thing as generated by
>> docs!
>> In other words, in
>> algHelp = QgsHelp::helpUrl( QStringLiteral( "
>> processing_algs/%1/%2.html#%3" ).arg( mAlgorithm->provider()->helpId(),
>> mAlgorithm->groupId(), mAlgorithm->name() ) );
>> replace the mAlgorithm->name() by something that replaces each space
>> between the words in name() by a hyphen?
>> mAlgorithm->groupId(), mAlgorithm->name().replace (' ', '-') ) );
>> Does that sound correct?
>> my 2cts,
>> Harrissou
>> 2018-02-09 12:26 GMT+01:00 matteo <matteo.ghetta at gmail.com>:
>>> > but yes, it's not an anchor that is created.
>>> changing the file name works fine. I have locally
>>> file:///home/matteo/lavori/QGIS/QGIS-Documentation/QGIS-Documentation/output/html/en/docs/user_manual/processing_algs/qgis/rasterterrainanalysis.html
>>> but not for anchors that are still taken from the header
>>> file:///home/matteo/lavori/QGIS/QGIS-Documentation/QGIS-Documentation/output/html/en/docs/user_manual/processing_algs/qgis/rasterterrainanalysis.html#hypsometric-curves
>>> even if the anchor name is different:
>>> .. _bla_bla_bla:
>>> Hypsometric curves
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180209/5ff0af0c/attachment.html>
