[QGIS-Developer] Processing Help system
Richard Duivenvoorde
rdmailings at duif.net
Fri Feb 9 04:22:38 PST 2018
(resending as was sent with wrong email...)
Ah, yes, confirmed... funny:
<span id="nearestneighbouranalysis"></span>
is usable as an anchor?
Well if it works (in all OS's and browsers?) it works :-)
Any html guru's here?
@Harrissou: I think Nyall's idea to use the id's is best, as the name
could have been translated?
Richard
On 09-02-18 12:16, Alexandre Neto wrote:
> but yes, it's not an anchor that is created.
> Alexandre Neto <senhor.neto at gmail.com <mailto:senhor.neto at gmail.com>>
> escreveu no dia sexta, 9/02/2018 às 11:12:
> I was able to use this local URL (note that I haven't renamed the
> rst file ):
> output/html/en/docs/user_manual/processing_algs/qgis/vector_analysis_tools.html#nearestneighbouranalysis
> Richard Duivenvoorde <rdmailings at duif.net
> <mailto:rdmailings at duif.net>> escreveu no dia sexta, 9/02/2018 às 11:10:
> I thought wat Alexandre was saying was ok, but trying it out, it
> seems
> just to create a 'span' with that id not a href#anchor ...
> Anybody else can try?
> Richard
> On 09-02-18 11:55, Alexandre Neto wrote:
> > From what I understand, we should stick to the algorithm ID. The
> > provider is already implicit by the file structure. Assuming
> that that
> > ID is unique across all the providers.
> > processing_algs > qgis > vector analysis tools
> > matteo <matteo.ghetta at gmail.com
> <mailto:matteo.ghetta at gmail.com> <mailto:matteo.ghetta at gmail.com
> <mailto:matteo.ghetta at gmail.com>>>
> > escreveu no dia sexta, 9/02/2018 às 10:44:
> > Hi Alexandre,
> > > We don't need to change the algorithms titles, we just
> need to add
> > an extra
> > > anchor with the algorithm ID before it:
> > > .. _nearestneighbouranalysis:
> > > Nearest neighbour analysis
> > > Description
> > > <put algorithm description here>
> > thanks for the hint.
> > I've already put anchors before each algorithm, but with the
> > provider name:
> > .. _qgis_nearestneighbouranalysis:
> > so I can get rid of the provider name and it should work
> correctly?
> > Thanks
> > Matteo
> > Alexandre Neto
> > @AlexNetoGeo
> > http://sigsemgrilhetas.wordpress.com
> > http://gisunchained.wordpress.com
> Alexandre Neto
> @AlexNetoGeo
> Alexandre Neto
> @AlexNetoGeo
