[QGIS-Developer] Concerns re UX of new "duplicate features" actions in 2.99
Mathieu Pellerin
nirvn.asia at gmail.com
Tue Feb 13 19:57:12 PST 2018
I share those concerns too.
The integration with parts of QGIS is sub-optimal. For e.g., the added (and
always visible) menu bar in the attribute form. I'm not sure is should be
there at all, and if so, certainly not when the layer's edit mode is OFF.
IMHO, I'd disable/remove less-than-optimal UI integration (such as the
above mentioned example), leave the less intrusive ones in there (the
action tool's actions), and revisit the UI in the 3.2 dev cycle.
Math
On Wed, Feb 14, 2018 at 10:34 AM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> Hi all,
> Just wanted to raise discussion about a concern I have with the new
> "duplicate feature" / "duplicate feature and redigitize" actions which
> have been added for 3.0.
> While I like the functionality, I believe we should re-think the UX of
> how it is exposed in the QGIS interface.
> Currently, it's implemented as a "feature action", so appears in
> numerous places throughout the QGIS UI, including:
> - the actions drop down submenu on the toolbar
> - within the right click menu for the "identify tool"
> - under the "actions" heading in the identify results dock for a feature
> - in a menu bar at the top of the form shown after adding a new feature
> - as an entry within the right click menu in the attribute table
> So my initial concern is that exposing it in all these places is
> overkill and far too prominent for this operation. But my deeper
> concern is that these actions skip the edit buffer and directly alter
> layers in place, even when those layers are not made editable
> (https://issues.qgis.org/issues/17852). So now we've got a menu item
> exposed in all these places which causes permanent changes to a layer,
> including in places which are not associated with editing at all (e.g.
> the identify tool right click menu).
> I'm also unsure what the actions would do in some contexts - e.g. if I
> create a new feature and then select "duplicate feature" in the popup
> form *before* this feature has even be finalized, what does it mean?
> I'd very much like to see this re-thought before our final release,
> and exposed in a more standard way via the advanced digitizing
> toolbar.
> Thoughts?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180214/6ba801a7/attachment-0001.html>
