[QGIS-Developer] Concerns re UX of new "duplicate features" actions in 2.99
Paolo Cavallini
cavallini at faunalia.it
Tue Feb 13 23:38:18 PST 2018
Agreed, thanks Nyall for raising this point.
IMHO:
* remove duplication, leaving it only under editing
* disable it when the layer is not under editing.
All the best.
Il 14/02/2018 04:57, Mathieu Pellerin ha scritto:
> I share those concerns too.
> The integration with parts of QGIS is sub-optimal. For e.g., the added
> (and always visible) menu bar in the attribute form. I'm not sure is
> should be there at all, and if so, certainly not when the layer's edit
> mode is OFF.
> IMHO, I'd disable/remove less-than-optimal UI integration (such as the
> above mentioned example), leave the less intrusive ones in there (the
> action tool's actions), and revisit the UI in the 3.2 dev cycle.
> Math
> On Wed, Feb 14, 2018 at 10:34 AM, Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> Hi all,
> Just wanted to raise discussion about a concern I have with the new
> "duplicate feature" / "duplicate feature and redigitize" actions which
> have been added for 3.0.
> While I like the functionality, I believe we should re-think the UX of
> how it is exposed in the QGIS interface.
> Currently, it's implemented as a "feature action", so appears in
> numerous places throughout the QGIS UI, including:
> - the actions drop down submenu on the toolbar
> - within the right click menu for the "identify tool"
> - under the "actions" heading in the identify results dock for a feature
> - in a menu bar at the top of the form shown after adding a new feature
> - as an entry within the right click menu in the attribute table
> So my initial concern is that exposing it in all these places is
> overkill and far too prominent for this operation. But my deeper
> concern is that these actions skip the edit buffer and directly alter
> layers in place, even when those layers are not made editable
> (https://issues.qgis.org/issues/17852
> <https://issues.qgis.org/issues/17852>). So now we've got a menu item
> exposed in all these places which causes permanent changes to a layer,
> including in places which are not associated with editing at all (e.g.
> the identify tool right click menu).
> I'm also unsure what the actions would do in some contexts - e.g. if I
> create a new feature and then select "duplicate feature" in the popup
> form *before* this feature has even be finalized, what does it mean?
> I'd very much like to see this re-thought before our final release,
> and exposed in a more standard way via the advanced digitizing
> toolbar.
> Thoughts?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
