[QGIS-Developer] When is Qt updated for the Windows releases?
Jürgen E. Fischer
jef at norbit.de
Wed Feb 14 06:07:31 PST 2018
Hi Nyall,
On Wed, 14. Feb 2018 at 23:59:07 +1100, Nyall Dawson wrote:
> > But if we update I'd do them with one of our point releases so that the new
> > release is build with then available Qt - the next nightlies would also pick
> > them up. Otherwise we'd have the release packages using a newer Qt then the
> > one they were built with.
> That's all fair enough. Does your no-upgrade plan include Qt bug fix
> releases? E.g. 5.9.4?
If there was a plan, it would include it. Now it's simply only done when there
is a significant need to do it (eg. QGIS doesn't build without it, we have to
support older version of Qt just to suit OSGeo4W or when it enables something
important; blurry yes). That also applies to many other things in OSGeo4W
(except for QGIS, GRASS and GDAL).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180214/ca3235ea/attachment.sig>
