[QGIS-Developer] Incorrect hidpi setting in 3.0 for OSX
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Feb 19 07:20:47 PST 2018
Hi all,
This always sounded very obscure to me...
Alessandro, can you recommend any value to test?
Cheers,
denis
Le lun. 19 févr. 2018 à 07:45, Alessandro Pasotti <apasotti at gmail.com> a
écrit :
> Hi,
> sorry if this does not apply to mac (I'm not a Mac user), but did you try
> to experiment with the following environment variables?
> QT_AUTO_SCREEN_SCALE_FACTOR
> QT_DEVICE_PIXEL_RATIO
> the effect may be different with different Qt versions and platforms.
> On Mon, Feb 19, 2018 at 7:32 AM, Jeremy Palmer <palmerjnz at gmail.com>
> wrote:
>> Thanks for starting this thread Nyall.
>> Ian not sure if it's relates to the HiDPI changes that occurred recently
>> (e.g maptool cursors becoming small) but I've also noted that since Xmas
>> the canvas is very sluggish when panning and zooming on Macosx and
>> burning through many More CPU cycles than 2.18 for the same operations.
>> Cheers
>> Jeremy
>> On 19/02/2018 19:14, "Nyall Dawson" <nyall.dawson at gmail.com> wrote:
>>> Hey all (specifically OSX devs)
>>> From a few open bug reports we have against the OSX build of 3.0, I
>>> gather that the OSX builds currently are not correctly handling hidpi
>>> screens.
>>> My understanding is that the builds are silently trying to scale the
>>> UI by pixel doubling/scaling - it's resulting in bugs like
>>> https://issues.qgis.org/issues/18043,
>>> https://issues.qgis.org/issues/17773, and
>>> https://issues.qgis.org/issues/15984.
>>> Does any OSX expert know why this is happening? I think the automatic
>>> pixel scaling should be switched off - while master isn't perfect with
>>> hidpi screens, it's usable and the benefits of the hidpi
>>> canvas/composer outweigh the remaining issues.
>>> Plus, I'd rather we use a single approach to hidpi scaling then have
>>> to worry about separate code paths for OSX.
>>> Nyall
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180219/3e29a4fe/attachment.html>
