[QGIS-Developer] Upcoming PROJ 5.0.0 release
Jürgen E. Fischer
jef at norbit.de
Mon Feb 19 13:17:14 PST 2018
Hi Kristian,
On Mon, 19. Feb 2018 at 19:21:48 +0000, Kristian Evers wrote:
> One minor thing I discovered was that the "About QGIS” dialog lists the
> version number as 4.9.3 instead of 5.0.0. Additionally it says “PROJ.4
> Version”, which in the future should instead simply be “PROJ Version” as per
> the release notes for the upcoming release [0]. I haven’t looked into how the
> text in the dialog is added, but in case it is hard-coded the PROJ version
> number is defined as PJ_VERSION in proj_api.h, or can be retrieved with the
> proj_info() function in the new proj.h API.
If proj 4 had that option, it would already be there - for proj 5 the version
it was built against (PJ_VERSION) and the version it's running with (proj_info)
is shown now (obviously only when QGIS is build against proj 5 or above).
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180219/af9cfeb2/attachment.sig>
