[QGIS-Developer] Upcoming PROJ 5.0.0 release
Kristian Evers kreve at sdfe.dk
Mon Feb 19 13:24:44 PST 2018
Of course, yes. The problem will sort itself out eventually then.
Thanks again, Jürgen, for adding the PROJ RC3-testing OSGeo4W package!
/Kristian
> On 19 Feb 2018, at 22:17, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Kristian,
> On Mon, 19. Feb 2018 at 19:21:48 +0000, Kristian Evers wrote:
>> One minor thing I discovered was that the "About QGIS” dialog lists the
>> version number as 4.9.3 instead of 5.0.0. Additionally it says “PROJ.4
>> Version”, which in the future should instead simply be “PROJ Version” as per
>> the release notes for the upcoming release [0]. I haven’t looked into how the
>> text in the dialog is added, but in case it is hard-coded the PROJ version
>> number is defined as PJ_VERSION in proj_api.h, or can be retrieved with the
>> proj_info() function in the new proj.h API.
> If proj 4 had that option, it would already be there - for proj 5 the version
> it was built against (PJ_VERSION) and the version it's running with (proj_info)
> is shown now (obviously only when QGIS is build against proj 5 or above).
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
