[QGIS-Developer] New Processing Help System summary
Alexandre Neto senhor.neto at gmail.com
Mon Feb 19 15:27:15 PST 2018
I agree. Adding sphinx anchors should be enough. Unless there are
algorithms from different providers usinf the same identifier, because in
sphinx we cannot have duplicated anchor's names.
Nyall Dawson <nyall.dawson at gmail.com> escreveu no dia segunda, 19/02/2018
às 22:40:
> On 19 February 2018 at 18:09, Paolo Cavallini <cavallini at faunalia.it>
> wrote:
> > Il 18/02/2018 22:48, Tim Sutton ha scritto:
> >> Thanks so much for the summary Matteo, it is really nice to see a
> >> summary of the current status list this!
> > it wuld be nice if the small but annoying issue about modules with names
> > with spaces would be solved; Nyall, could the same approach you used for
> > link names also be used for anchors?
> I don't think this is a good idea - it means we have code in master
> which will need updating if the help files are edited and the
> algorithm headings tweaked. That'll get quite messy when different
> versions/branches are involved (both on the qgis and documentation
> side).
> I'd rather a fix on the documentation side which uses the invisible
> link anchor matching the algorithm id - which is fixed and guaranteed
> not to change. Weren't earlier experiments for this approach
> successful?
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180219/ba2b6ba0/attachment.html>
More information about the QGIS-Developer mailing list
