[QGIS-Developer] QGIS 3.0 Sluggish on MacOS 10.13 with Retina Display
Jeremy Palmer palmerjnz at gmail.com
Tue Feb 20 12:34:08 PST 2018
Hi All,
For some time I've been noticing that QGIS 3.0 on MacOSX has sluggish
canvas redraw speeds. When comparing between QGIS 2.18 and 3.0 I see ~4x
more CPU activity in 3.0 when performing the same set of operations on the
same dataset.
My test case was using a single raster VRT with overviews, and zooming in
and panning around the map cavnas for 20 sec. On average each time I tested
this case the total used CPU time for 2.18 was about 6 secs, but in
3.0dev-64369f8099 (complied against QT 5.10.0 with homebrew) I get total
CPU time of 25 secs. In QGIS 3.0 most of the time the application is using
100% CPU (one core) and spikes to about 180-200% CPU when the canvas
redraws are performed. When using a profiler it seems much of the time is
taken up in QImage::copy(QRect const&) within two seperate, but equivalent,
call subtrees. See [1] for more info.
Is anyone else seeing slow map canvas performance in QGIS 3.0 on MacOSX?
Cheers,
Jeremy
[1]  - https://imgur.com/a/ZSRTf
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180221/8ad8193e/attachment.html>
More information about the QGIS-Developer mailing list
