[QGIS-Developer] Where are value maps / defaults stored on shape file layers?
Nyall Dawson nyall.dawson at gmail.com
Fri Feb 23 23:12:25 PST 2018
On 24 February 2018 at 17:05, Patrick Dunford <enzedrailmaps at gmail.com> wrote:
> It would seem this data is stored in the project file?
> Given I can't produce a corrupted project file (I can only produce the files
> for the affected laye) is there any point in filing a bug for this.
What platform are you running on? Which GDAL version?
If I recall correctly this was fixed in GDAL around 6-12 months ago.
Nyall
> On 24/02/18 20:01, Patrick Dunford wrote:
>> Good evening (here)
>> I had Qgis 2.99 crash and it left the shape file data with three of the
>> data files that make up the shapefile, with _packed in their name.
>> Although renaming the files got the data back, the value maps and default
>> values for new features for this layer have disappeared.
>> Is there a particular file that stores this data for the layer (before I
>> decide whether this could be a bug or not)?
>> Thanks
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
