[QGIS-Developer] Where are value maps / defaults stored on shape file layers?
Patrick Dunford
enzedrailmaps at gmail.com
Sat Feb 24 00:37:18 PST 2018
Bionic, running the most up to date build that is available at the
moment (built 23 Feb I think)
On 24/02/18 20:12, Nyall Dawson wrote:
> On 24 February 2018 at 17:05, Patrick Dunford <enzedrailmaps at gmail.com> wrote:
>> It would seem this data is stored in the project file?
>> Given I can't produce a corrupted project file (I can only produce the files
>> for the affected laye) is there any point in filing a bug for this.
> What platform are you running on? Which GDAL version?
> If I recall correctly this was fixed in GDAL around 6-12 months ago.
> Nyall
>> On 24/02/18 20:01, Patrick Dunford wrote:
>>> Good evening (here)
>>> I had Qgis 2.99 crash and it left the shape file data with three of the
>>> data files that make up the shapefile, with _packed in their name.
>>> Although renaming the files got the data back, the value maps and default
>>> values for new features for this layer have disappeared.
>>> Is there a particular file that stores this data for the layer (before I
>>> decide whether this could be a bug or not)?
>>> Thanks
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
