[QGIS-Developer] Processing doc - sphinx - anchors
Alexander Bruy alexander.bruy at gmail.com
Sat Feb 24 03:10:00 PST 2018
Hi Matteo,
well, previously it worked in the exactly this way, link was created
using algorithm id which eventually is a concatenation of the provider
name and algorithm name. But on requrest from documentation team
this behaviour was changed to current approach.
So now you want to go back to links like this
https://docs.qgis.org/testing/en/docs/user_manual/processing_algs/qgis/vectoroverlay.html#qgisintersection
Is this correct? Just want to clarify before implemeting it to avoid yet another
round of discussions and "fixing".
2018-02-24 12:46 GMT+02:00 matteo <matteo.ghetta at gmail.com>:
> Hi devs,
> for those of you that followed the discussion you know we have some
> issues with the sphinx anchors and the name of the algorithms in the
> code if the name of the algorithm has more than one word (e.g. count
> point in polygon)
> We were able to manage it by putting an anchor with the exact name of
> the algorithm (e.g. `.. _countpointsinpolygon): this creates a span tag
> in the html that behaves like an anchor.
> Future issues will appear if we have the same anchor name for different
> algorithm, e.g. slope of GDAL and slope of QGIS. Sphinx does not accept
> 2 anchor with the same name, even if in different files.
> One proposal would be to change the name of the algorithm in the code
> and put the name of the provider before the name of the algorithm:
> `gdalslope` vs `qgisslope`
> then we are sure to have unique algorithm names.
> Feedback are very welcome, but I think this should be fixed (of course
> also in other way, maybe sphinx side?)
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
More information about the QGIS-Developer mailing list
