[QGIS-Developer] mirroring qgis.org repos
Richard Duivenvoorde
rdmailings at duif.net
Tue Jan 2 07:14:10 PST 2018
Ok, (more) clear :-)
Easiest (for me now) is if you could use this url:
https://qgis.org/ubuntugis/
The (letsencrypt) certificate there is valid for
qgis.org (going via cache)
version.qgis.org (NOT going via cache)
and download.qgis.org (not even a DNS entry)
So IF
gives cloudflare/certificate problems,
you could use
https://version.qgis.org/ubuntugis/
Note that 144.76.174.102 will be the ip address for the upcoming future.
It is not that we will change back to the other one.
If all this is not working, I could add ubuntu.qgis.org to the
certificate too (and probably debian.qgis.org then too???)
Let me know what you preference is.
Regards,
Richard
On 02-01-18 14:58, Bernhard Ströbl wrote:
> Hi Richard,
> thank you for your answer. Our goal is the same as two years ago: We
> want to mirror the repo locally, i.e. we want to see all the files.
> This command currently works:
> debmirror --dist=xenial --section=main --arch=i386,amd64 --cleanup
> --host=144.76.174.102 --root=ubuntugis-ltr --method=http --rsync-extra=none
> BUT:
> 1) if the IP changes we will have to call again
> 2) if http is shut off we cannot access via https because the SSL
> certificate does not contain the address 144.76.174.102 (certificate
> verification fails)
> regards
> Bernhard
> Am 02.01.2018 um 14:01 schrieb Richard Duivenvoorde:
>> Hi Bernhard,
>> Can you provide some more information on what you exactly want to see?
>> http://ubuntu.qgis.org ?
>> That one was still pointing to our old server (which since... I think 3
>> weeks does not have a webserver running anymore).
>> I let it point to our new qgis2 server now (144.76.174.102).
>> (note that this one is NOT being cached by cloudflare, so I doubt it is
>> 'the same problem' as earlier)
>> And I see now:
>> http://ubuntu.qgis.org/ubuntugis/
>> which is a repo.
>> Fixed like this?
>> Sorry for the inconvenience.
>> Regards,
>> On 02-01-18 09:20, Bernhard Ströbl wrote:
>>> Hi,
>>> I wish everybody a good start in 2018!
>>> We have -again- a problem mirroring the QGIS repos locally, see [1]. The
>>> ubuntu subdomain is not accessible anymore and going directly to
>>> qgis.org results in the same error as two years ago.
>>> best regards
>>> Bernhard
>>> [1]
>>> http://lists.osgeo.org/pipermail/qgis-developer/2016-January/041107.html
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 16667 (20180102) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> signature database 16669 (20180102) __________
>> http://www.eset.com
