[QGIS-Developer] Processing plugin - Set style on resulting layer
Nyall Dawson
nyall.dawson at gmail.com
Thu Jan 4 23:46:13 PST 2018
On 5 January 2018 at 17:34, Alexander Bruy <alexander.bruy at gmail.com> wrote:
> Processing allows to define styles for outpus on the per-algorithm basis.
> Just open algorithm context menu by right-clicking on it and select "Edit
> rendering styles for outputs". In the dialog you can assign styles for each
> algorithm output. These styles will be applied to outputs automatically
> after algorithm execution.
> Hope this helps.
That works for a user, but I think Jakob is after a way for an
algorithm to define a style which is always used for the output for
that algorithm.
Is this correct?
Nyall
