[QGIS-Developer] GRIB files projection errors
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Tue Jan 9 12:37:49 PST 2018
Hi Paolo,
You can download the files directly from ECMWF. Maybe it is a bug with the
ZyGrib data processing.
For Crayfish you can compile it yourself:
https://github.com/lutraconsulting/qgis-crayfish-plugin/blob/master/README.md#installing-crayfish-on-linux
Regards
Saber
On 9 Jan 2018 8:14 pm, "Paolo Cavallini" <cavallini at faunalia.it> wrote:
Hi Saber,
thanks for checking. The sample mentioned in the ticket loads fine, but
its SRS is not recognized correctly (it appears as a custom EPSG,
whereas it should be 4326, I guess).
Further tests reveal that other gribs (downloaded with ZyGrib) have an
incorrect extent, and there fore are not loaded correctly. You can check
yourself or use this sample:
http://www.faunalia.eu/~paolo/grib2.bz2
As for crayfish, I'd need a solution using plain QGIS, as I'd like to
build a plugin based on grib. Furthermore, I would not like to use
non-Debian binaries on my system.
All the best.
Il 09/01/2018 14:53, Saber Razmjooei ha scritto:
> Hi Paolo,
> It works fine for me.
> Have you tried to open it with Crayfish as it will handle the bands
> properly?
> Regards
> Saber
> On 9 January 2018 at 12:08, Paolo Cavallini <cavallini at faunalia.it
> <mailto:cavallini at faunalia.it>> wrote:
> Hi all,
> loading a GRIB file does not work properly, because of a projection
and
> extent issue (mentioned in https://issues.qgis.org/issues/17219
> <https://issues.qgis.org/issues/17219>).
> The issue may reside in GDAL. Has anyone already worked on this?
> Thanks.
> Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
> <http://www.faunalia.eu/training.html>
> https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis
> <https://www.google.com/trends/explore?date=all&geo=IT&q=qgis,arcgis>
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Saber Razmjooei
> www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk>
> +44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180109/9889d0e9/attachment.html>
