[QGIS-Developer] Fresh QGIS3 misses all kind of 'default' options on first start
Nathan Woodrow madmanwoo at gmail.com
Wed Jan 10 05:00:43 PST 2018
I will have a look at what options we have next Monday hopefully.
On Wed., 10 Jan. 2018, 10:40 pm Jorge Gustavo Rocha, <jgr at di.uminho.pt>
wrote:
> Hi Richard,
> Good point!
> We have in QGIS3 a new qgis_global_settings.ini file where we can put
> global default settings. These global settings can be override later by
> the users.
> I think we need to start populating this file with reasonable settings.
> You might suggest some of those settings to start with.
> Regards,
> Jorge Gustavo
> On 10-01-2018 11:53, Richard Duivenvoorde wrote:
> > Hi Devs,
> > Currently if you start QGIS3 for the first time, all kind of default
> > options (from the Options Dialog) are not yet 'saved' to QgsSettings().
> > To test:
> > - remove ~/.share/local/QGIS
> > - start QGIS
> > - choose 'I want a clean start. Don't import my QGIS 2 settings.'
> > Now in Python console type:
> > QgsSettings().value( "help/helpSearchPath" )
> > which will return an emtpy list (of search paths)
> > Open Settings/Options/System properties and see there is:
> > https://docs.qgis.org/$qgis_short_version/$qgis_locale/docs/user_manual/
> > in Documentation paths there.
> > NOW click OK and
> https://docs.qgis.org/$qgis_short_version/$qgis_locale/docs/user_manual/']
> > So Question: is there a way to 'silently' save all those options for a
> > fresh user? I'm not so familiar with how those dialogs are constructed,
> > so can we 'submit' all tabs in one? Or should we submit them one by one?
> > Ah, it appears that clicking OK once from whatever tab will 'save' (at
> > least this path) to QgsSettings()...
> > Otherwise, current situation will be that a new user upon clicking
> > any(!) help button will always be shown with the daft "Oops! QGIS help
> > is currently not available. This is likely because: ... " message.
> > See also:
> > https://issues.qgis.org/issues/17670
> > https://issues.qgis.org/issues/17598
> > Regards,
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> J. Gustavo
> Jorge Gustavo Rocha
> Departamento de Informática
> Universidade do Minho
> 4710-057 Braga
> Tel: +351 253604480
> Fax: +351 253604471
> Móvel: +351 910333888
> skype: nabocudnosor
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180110/265969c7/attachment.html>
More information about the QGIS-Developer mailing list
