[QGIS-Developer] QGIS3 - Processing : display the HTML outputs
Alexander Bruy
alexander.bruy at gmail.com
Wed Jan 10 22:10:35 PST 2018
Hi Michaël,
HTML outputs does not open automatically. You need to open Results panel
to see them. Double-clicking on the result item will open it in the
default browser.
Hope this helps
2018-01-10 21:37 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> Hi all,
> I am trying QGIS 3 these days. In the processing toolbox, when I run some
> algs with an HTML output, the processing dialog is closed just after the
> results are produced, and not displayed.
> You can test this behaviour with the Raster statistics algs.
> What is the python way to tell QGIS to display the HTML results ? I tried
> this
> https://github.com/ghtmtt/DataPlotly/pull/65/files#diff-c2089b16fcc7b309bc3bf9e5a9f6e114R110
> Should I add an HTML output ?
> Regards
> Michaël
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
