[QGIS-Developer] QGIS3 - Processing : display the HTML outputs
kimaidou
kimaidou at gmail.com
Wed Jan 10 23:29:45 PST 2018
Hi Alexander,
It helps a lot thanks. It solves the "display outputs" issue.
Another issue I notice : IMHO I think the "auto-close after run" behaviour
is a bit cumbersome for the user. It means the user need to reopen the alg
dialog each time after a successfull run. Imagine you would like to test
different values for inputs. Instead of run / go back to the form to change
an input / run, you need to run / reopen the alg / re-enter all inputs (you
have lost the previous values) / run / reopen ...
We should have an option to let the user decide "Keep the alg dialog open"
which make it possible to run the same alg more than once. Perhaps there is
an hidden option or setting to do so ?
Regards
Michaël
2018-01-11 7:10 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Michaël,
> HTML outputs does not open automatically. You need to open Results panel
> to see them. Double-clicking on the result item will open it in the
> default browser.
> Hope this helps
> 2018-01-10 21:37 GMT+02:00 kimaidou <kimaidou at gmail.com>:
> > Hi all,
> > I am trying QGIS 3 these days. In the processing toolbox, when I run some
> > algs with an HTML output, the processing dialog is closed just after the
> > results are produced, and not displayed.
> > You can test this behaviour with the Raster statistics algs.
> > What is the python way to tell QGIS to display the HTML results ? I tried
> > this
> > https://github.com/ghtmtt/DataPlotly/pull/65/files#diff-
> c2089b16fcc7b309bc3bf9e5a9f6e114R110
> > Should I add an HTML output ?
> > Regards
> > Michaël
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180111/4685541d/attachment.html>
