[QGIS-Developer] QGIS3 - Processing : display the HTML outputs
kimaidou
kimaidou at gmail.com
Wed Jan 10 23:39:19 PST 2018
Ok, I have found the option in QGIS Options dialog / Tab Processing / Check
"Keep dialog open after running an algorithm". I think this option should
be checked as a default value. Any opinion on this ?
I trie the Result panel : for the "Raster layer statistics" alg. I can see
the run listed in the Processing result viewer. I think we should propose a
way to display the result directly inside QGIS for the text, html and other
"readable" output format.
Michaël
2018-01-11 8:29 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi Alexander,
> It helps a lot thanks. It solves the "display outputs" issue.
> Another issue I notice : IMHO I think the "auto-close after run" behaviour
> is a bit cumbersome for the user. It means the user need to reopen the alg
> dialog each time after a successfull run. Imagine you would like to test
> different values for inputs. Instead of run / go back to the form to change
> an input / run, you need to run / reopen the alg / re-enter all inputs (you
> have lost the previous values) / run / reopen ...
> We should have an option to let the user decide "Keep the alg dialog open"
> which make it possible to run the same alg more than once. Perhaps there is
> an hidden option or setting to do so ?
> Regards
> Michaël
> 2018-01-11 7:10 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
>> Hi Michaël,
>> HTML outputs does not open automatically. You need to open Results panel
>> to see them. Double-clicking on the result item will open it in the
>> default browser.
>> Hope this helps
>> 2018-01-10 21:37 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> > Hi all,
>> > I am trying QGIS 3 these days. In the processing toolbox, when I run
>> some
>> > algs with an HTML output, the processing dialog is closed just after the
>> > results are produced, and not displayed.
>> > You can test this behaviour with the Raster statistics algs.
>> > What is the python way to tell QGIS to display the HTML results ? I
>> tried
>> > this
>> > https://github.com/ghtmtt/DataPlotly/pull/65/files#diff-c208
>> 9b16fcc7b309bc3bf9e5a9f6e114R110
>> > Should I add an HTML output ?
>> > Regards
>> > Michaël
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180111/f537ebb5/attachment-0001.html>
