[QGIS-Developer] QGIS3 - Processing : display the HTML outputs
Andreas Neumann a.neumann at carto.net
Thu Jan 11 00:06:23 PST 2018
I agree. I would prefer to have the "Keep dialog open after running an
algorithm" on by default.
Andreas
On 2018-01-11 08:39, kimaidou wrote:
> Ok, I have found the option in QGIS Options dialog / Tab Processing / Check "Keep dialog open after running an algorithm". I think this option should be checked as a default value. Any opinion on this ?
> I trie the Result panel : for the "Raster layer statistics" alg. I can see the run listed in the Processing result viewer. I think we should propose a way to display the result directly inside QGIS for the text, html and other "readable" output format.
> Michaël
> 2018-01-11 8:29 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi Alexander,
> It helps a lot thanks. It solves the "display outputs" issue.
> Another issue I notice : IMHO I think the "auto-close after run" behaviour is a bit cumbersome for the user. It means the user need to reopen the alg dialog each time after a successfull run. Imagine you would like to test different values for inputs. Instead of run / go back to the form to change an input / run, you need to run / reopen the alg / re-enter all inputs (you have lost the previous values) / run / reopen ...
> We should have an option to let the user decide "Keep the alg dialog open" which make it possible to run the same alg more than once. Perhaps there is an hidden option or setting to do so ?
> Regards Michaël
> 2018-01-11 7:10 GMT+01:00 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Michaël,
> HTML outputs does not open automatically. You need to open Results panel
> to see them. Double-clicking on the result item will open it in the
> default browser.
> Hope this helps
> 2018-01-10 21:37 GMT+02:00 kimaidou <kimaidou at gmail.com>:
>> Hi all,
>> I am trying QGIS 3 these days. In the processing toolbox, when I run some
>> algs with an HTML output, the processing dialog is closed just after the
>> results are produced, and not displayed.
>> You can test this behaviour with the Raster statistics algs.
>> What is the python way to tell QGIS to display the HTML results ? I tried
>> this
>> https://github.com/ghtmtt/DataPlotly/pull/65/files#diff-c2089b16fcc7b309bc3bf9e5a9f6e114R110 [1]
>> Should I add an HTML output ?
>> Regards
>> Michaël
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer [2]
> Alexander Bruy
Links:
[1]
[2] https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180111/48ebcda0/attachment.html>
More information about the QGIS-Developer mailing list
