[QGIS-Developer] QgsDockWidget does not seem to work with loadUiType
C Hamilton
adenaculture at gmail.com
Thu Jan 11 13:28:26 PST 2018
Thanks to everyone for confirming that this is not just me and that it is a
bug. So the question I now have is whether it is better to use
uic.loadUiType or to compile the ui to python code from a best practice
point of view?
Best wishes,
Calvin
On Thu, Jan 11, 2018 at 8:24 AM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> Hi all,
> I think this is not currently feasible with PyQt5 at the moment (using
> QgsDockWidget as a top class for a UI and loading it with uic.loadUiType)
> Here is a description of the issue on PyQt mailing list
> https://www.riverbankcomputing.com/pipermail/pyqt/2017-October/039647.html
> Here is a part of the reply from Phil Thomson:
> > I can confirm it is a bug, however the fix is non-trivial so it won't
> get fixed quickly. The fundamental problem is that the code has the
> assumption that all custom widgets will reside in the PyQt5 package
> hard-coded (but even then it's not quite as simple as that).
> I just pinged Phil to get an update on this as he said he would fix it.
> Best wishes,
> Denis
> Le mer. 10 janv. 2018 à 18:02, Nyall Dawson <nyall.dawson at gmail.com> a
> écrit :
>> On 11 January 2018 at 07:37, C Hamilton <adenaculture at gmail.com> wrote:
>> > I seem to remember seeing something that said that QgsDockWidget should
>> be
>> > used rather than QDockWidget. I was trying it today, but it generates
>> the
>> > error below in this line of code.
>> > FORM_CLASS, _ = loadUiType(os.path.join(
>> > os.path.dirname(__file__), 'ui/zoomToLatLon.ui'))
>> > Has anyone had problems with this or should I not use QgsDockWidget and
>> > stick with QDockWiget? I'm trying this on QGIS 2.99.
>> > AttributeError: module 'PyQt5.QtWidgets' has no attribute
>> 'QgsDockWidget'
>> It's not a PyQt class - it's in the QGIS gui library:
>> from qgis.gui import QgsDockWidget
>> Nyall
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180111/efde70a9/attachment.html>
