[QGIS-Developer] QgsDockWidget does not seem to work with loadUiType
Denis Rouzaud denis.rouzaud at gmail.com
Thu Jan 11 13:47:20 PST 2018
Well, I think using pyuic is the only way at the moment to use
QgsDockWidget as top widget.
But for any other case, using uic.loadUiType is eaiser since there no
Python path to deal with when using pyuic.
Cheers,
Denis
Le jeu. 11 janv. 2018 à 17:28, C Hamilton <adenaculture at gmail.com> a écrit :
> Thanks to everyone for confirming that this is not just me and that it is
> a bug. So the question I now have is whether it is better to use
> uic.loadUiType or to compile the ui to python code from a best practice
> point of view?
> Best wishes,
> Calvin
> On Thu, Jan 11, 2018 at 8:24 AM, Denis Rouzaud <denis.rouzaud at gmail.com>
> wrote:
>> Hi all,
>> I think this is not currently feasible with PyQt5 at the moment (using
>> QgsDockWidget as a top class for a UI and loading it with uic.loadUiType)
>> Here is a description of the issue on PyQt mailing list
>> https://www.riverbankcomputing.com/pipermail/pyqt/2017-October/039647.html
>> Here is a part of the reply from Phil Thomson:
>> > I can confirm it is a bug, however the fix is non-trivial so it won't
>> get fixed quickly. The fundamental problem is that the code has the
>> assumption that all custom widgets will reside in the PyQt5 package
>> hard-coded (but even then it's not quite as simple as that).
>> I just pinged Phil to get an update on this as he said he would fix it.
>> Best wishes,
>> Denis
>> Le mer. 10 janv. 2018 à 18:02, Nyall Dawson <nyall.dawson at gmail.com> a
>> écrit :
>>> On 11 January 2018 at 07:37, C Hamilton <adenaculture at gmail.com> wrote:
>>> > I seem to remember seeing something that said that QgsDockWidget
>>> should be
>>> > used rather than QDockWidget. I was trying it today, but it generates
>>> the
>>> > error below in this line of code.
>>> > FORM_CLASS, _ = loadUiType(os.path.join(
>>> >     os.path.dirname(__file__), 'ui/zoomToLatLon.ui'))
>>> > Has anyone had problems with this or should I not use QgsDockWidget and
>>> > stick with QDockWiget? I'm trying this on QGIS 2.99.
>>> > AttributeError: module 'PyQt5.QtWidgets' has no attribute
>>> 'QgsDockWidget'
>>> It's not a PyQt class - it's in the QGIS gui library:
>>> from qgis.gui import QgsDockWidget
>>> Nyall
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180111/08dcaf93/attachment.html>
More information about the QGIS-Developer mailing list
