[QGIS-Developer] map_id variable of 3d view?
Andreas Neumann
a.neumann at carto.net
Fri Jan 12 13:49:32 PST 2018
There is a variable called @map_id - which is 'canvas' for the main QGIS
map canvas. In map composer it can have a user-defined id. I wonder,
what is the map_id of a 3D canvas? And what are the map_ids of
additional 2D canvases besides the main one?
The reason I ask is that I want to create symbology rules for 2d only.
The same symbology rule should be supressed in the 3d view, because in
3d there are other representations (cylinder, spheres, models). So I
thought I could make a symbology rule that says "@map_id != '3dcanvas'"
Thanks for your help,
Andreas
