[QGIS-Developer] How to access advanced snapping configuration in QGIS master?
Denis Rouzaud denis.rouzaud at gmail.com
Mon Jan 15 05:36:06 PST 2018
Hi Andreas,
This is not really a bug.
The dialog can still be open from application menu -> snapping config.
The toolbar only allows to switch between already configured mode.
Although, I am working on a "bugfix" to show the snapping config under the
tool bar.
Cheers,
Denis
Le lun. 15 janv. 2018 à 09:26, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi,
> With current master I cannot find a way to access the "advanced snapping
> configuration" - the panel or dialogue that allow to set snapping
> settings for multiple layers at once.
> There is a drop-down button labeled "Advanced configuration" - but
> nothing happens. No dialogue or panel opens.
> Is this a bug or do I not understand how this works?
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/80114b34/attachment.html>
More information about the QGIS-Developer mailing list
