[QGIS-Developer] How to access advanced snapping configuration in QGIS master?
Andreas Neumann
a.neumann at carto.net
Mon Jan 15 05:40:40 PST 2018
Hi Denis,
oh - it is in the project menu. I was searching for it in the settings
menu ;-)
All these changes ... why was it moved from the settings to the Project
menu?
Anyway. Thanks for the hint! Much appreciated!
Andreas
On 15.01.2018 14:36, Denis Rouzaud wrote:
> Hi Andreas,
> This is not really a bug.
> The dialog can still be open from application menu -> snapping config.
> The toolbar only allows to switch between already configured mode.
> Although, I am working on a "bugfix" to show the snapping config under
> the tool bar.
> Cheers,
> Denis
> Le lun. 15 janv. 2018 à 09:26, Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> a écrit :
> Hi,
> With current master I cannot find a way to access the "advanced
> snapping
> configuration" - the panel or dialogue that allow to set snapping
> settings for multiple layers at once.
> There is a drop-down button labeled "Advanced configuration" - but
> nothing happens. No dialogue or panel opens.
> Is this a bug or do I not understand how this works?
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/57ec2a06/attachment-0001.html>
