[QGIS-Developer] How to access advanced snapping configuration in QGIS master?
Denis Rouzaud denis.rouzaud at gmail.com
Mon Jan 15 05:45:53 PST 2018
Hi Andreas,
You're not the first one hitting this.
See https://issues.qgis.org/issues/16596
The snapping config is mainly application wise before being project
specified.
Denis
Le lun. 15 janv. 2018 à 09:40, Andreas Neumann <a.neumann at carto.net> a
écrit :
> Hi Denis,
> oh - it is in the project menu. I was searching for it in the settings
> menu ;-)
> All these changes ... why was it moved from the settings to the Project
> menu?
> Anyway. Thanks for the hint! Much appreciated!
> Andreas
> On 15.01.2018 14:36, Denis Rouzaud wrote:
> Hi Andreas,
> This is not really a bug.
> The dialog can still be open from application menu -> snapping config.
> The toolbar only allows to switch between already configured mode.
> Although, I am working on a "bugfix" to show the snapping config under the
> tool bar.
> Cheers,
> Denis
> Le lun. 15 janv. 2018 à 09:26, Andreas Neumann <a.neumann at carto.net> a
> écrit :
>> Hi,
>> With current master I cannot find a way to access the "advanced snapping
>> configuration" - the panel or dialogue that allow to set snapping
>> settings for multiple layers at once.
>> There is a drop-down button labeled "Advanced configuration" - but
>> nothing happens. No dialogue or panel opens.
>> Is this a bug or do I not understand how this works?
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180115/d3abcb4f/attachment.html>
More information about the QGIS-Developer mailing list
