[QGIS-Developer] How to access advanced snapping configuration in QGIS master?
Mathieu Pellerin
nirvn.asia at gmail.com
Mon Jan 15 18:02:06 PST 2018
Denis,
Actually, all of the settings in the snapping config dialog are
project-specific and do not persist across projects. The application-wide
snapping settings are found in the options dialog (under the digitizing
tab).
Math
On Mon, Jan 15, 2018 at 8:45 PM, Denis Rouzaud <denis.rouzaud at gmail.com>
wrote:
> Hi Andreas,
> You're not the first one hitting this.
> See https://issues.qgis.org/issues/16596
> The snapping config is mainly application wise before being project
> specified.
> Denis
> Le lun. 15 janv. 2018 à 09:40, Andreas Neumann <a.neumann at carto.net> a
> écrit :
>> Hi Denis,
>> oh - it is in the project menu. I was searching for it in the settings
>> menu ;-)
>> All these changes ... why was it moved from the settings to the Project
>> menu?
>> Anyway. Thanks for the hint! Much appreciated!
>> Andreas
>> On 15.01.2018 14:36, Denis Rouzaud wrote:
>> Hi Andreas,
>> This is not really a bug.
>> The dialog can still be open from application menu -> snapping config.
>> The toolbar only allows to switch between already configured mode.
>> Although, I am working on a "bugfix" to show the snapping config under
>> the tool bar.
>> Cheers,
>> Denis
>> Le lun. 15 janv. 2018 à 09:26, Andreas Neumann <a.neumann at carto.net> a
>> écrit :
>>> Hi,
>>> With current master I cannot find a way to access the "advanced snapping
>>> configuration" - the panel or dialogue that allow to set snapping
>>> settings for multiple layers at once.
>>> There is a drop-down button labeled "Advanced configuration" - but
>>> nothing happens. No dialogue or panel opens.
>>> Is this a bug or do I not understand how this works?
>>> Thanks,
>>> Andreas
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180116/5ef25fb9/attachment.html>
