[QGIS-Developer] Plugin for both QGIS2 and QGIS3
Javier Becerra Elcinto javier at panoimagen.com
Tue Jan 16 23:27:38 PST 2018
Hi Simon,
We have used the approach of qgis2compat: we get our code running on
QGis3 with new API calls, and use a small compatibility layer to get
that same code running on QGis2. It is a bit of work, but seems to be
working fine.
However the wiki
(https://github.com/qgis/QGIS/wiki/Plugin-migration-to-QGIS-3) now says
that qgis2compat has been deprecated; I do not know if it is because
that route is a dead-end, if other people are just making two different
versions of the plugin.
Regards,
Javier
El 16/01/2018 a las 14:53, Simon Gröchenig escribió:
> Hi,
> I aim to release a QGIS3-version of my QGIS plugin "GPX Segment
> Importer". I would like to ask you if there exists a common approach
> for releasing versions for both QGIS2 and QGIS3? Should I create a new
> plugin for QGIS3 or can I somehow use the existing plugin for both?
> Simon
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
