[QGIS-Developer] Plugin for both QGIS2 and QGIS3
Enrico Ferreguti
enricofer at gmail.com
Wed Jan 17 00:06:42 PST 2018
I both migrate plugin keeping qgis2 compatibility (
https://github.com/enricofer/attributepainter) or branching to qgis3 only (
https://github.com/enricofer/go2streetview)
Having to carry out 3 migrations in one: python2 to python3, QT4 to QT5,
PyQt2 to PyQt3, in my experience I strongly suggest you to branch to Qgis3
only, leaving the qgis2 compatibility to simpler plugins.
You will get a more readable and efficient code, and you'll get the
opportunity to understand and exploit the api breaks benefits.
Regards
Enrico Ferreguti
2018-01-17 8:27 GMT+01:00 Javier Becerra Elcinto <javier at panoimagen.com>:
> Hi Simon,
> We have used the approach of qgis2compat: we get our code running on QGis3
> with new API calls, and use a small compatibility layer to get that same
> code running on QGis2. It is a bit of work, but seems to be working fine.
> However the wiki (https://github.com/qgis/QGIS/
> wiki/Plugin-migration-to-QGIS-3) now says that qgis2compat has been
> deprecated; I do not know if it is because that route is a dead-end, if
> other people are just making two different versions of the plugin.
> Regards,
> Javier
> El 16/01/2018 a las 14:53, Simon Gröchenig escribió:
>> Hi,
>> I aim to release a QGIS3-version of my QGIS plugin "GPX Segment
>> Importer". I would like to ask you if there exists a common approach for
>> releasing versions for both QGIS2 and QGIS3? Should I create a new plugin
>> for QGIS3 or can I somehow use the existing plugin for both?
>> Simon
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180117/d2240eb4/attachment.html>
