[QGIS-Developer] Last call for switching to github issue tracker
Nyall Dawson
nyall.dawson at gmail.com
Wed Jan 17 15:07:45 PST 2018
On 18 January 2018 at 08:06, Tim Sutton <tim at kartoza.com> wrote:
> So I would suggest raising a vote on the motion:
> “We should adopt GitHub issues for reporting issues in 3.0 and restrict Redmine for the management of issues in QGIS 2.x”.
> After there are no more active 2.x releases, we make the Redmine tracker read only and keep it around as an archive. We could put into the GitHub issue template: “Only use this tracker for 3.x related issues” and similar message on Redmine indicating that it should only be used for 2.x issues. It will unfortunately leave us in the position where you need to check to issue trackers for your issue which is going to suck a bit.
I'm a bit unclear where 2.18 fits in - would Redmine be open for new
2.18 bugs? Or would they be reported on github?
Nyall
