[QGIS-Developer] Example script for Processing in QGIS 3
Alexander Bruy alexander.bruy at gmail.com
Tue Jan 23 00:28:46 PST 2018
There are some scripts in the Processing tests
https://github.com/qgis/QGIS/tree/master/python/plugins/processing/tests/testdata/scripts
2018-01-23 10:19 GMT+02:00 Anita Graser <anitagraser at gmx.at>:
> On Jan 23, 2018 1:19 AM, "Nyall Dawson" <nyall.dawson at gmail.com> wrote:
>> On 23 January 2018 at 04:12, Anita Graser <anitagraser at gmx.at> wrote:
>> > On Sat, Jan 20, 2018 at 12:40 PM, Anita Graser <anitagraser at gmx.at>
>> > wrote:
>> >> Do we have any working example scripts for Processing in QGIS 3?
>> >> I tried using "Get scripts from on-line collection" but they all seem
>> >> broken:
>> >> https://issues.qgis.org/issues/17897
>> > Is there any documentation how Processing scripts have changed?
>> See https://github.com/qgis/QGIS/pull/4841 - needs completion and
>> merging though.
> Thank you for the pointer Nyall. That's certainly a start but as you mention
> correctly, it still seems incomplete. For example, it currently doesn't help
> me figure out how to fix
> This script has a syntax errors. Problem with line: ##output=output vector
> There is a line in the PR about vector outputs but it's a bit cryptic:
> - OutputVector ->
> - processAlgorithm has a new signature....
> Use parameterAsSink instead of getOutputFromName
> Regards,
> Anita
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
More information about the QGIS-Developer mailing list
