[QGIS-Developer] Changes to processing gdal:translate?
Tom Chadwin
tom.chadwin at nnpa.org.uk
Fri Jan 26 08:58:51 PST 2018
No, my mistake. I think there might be an issue with the processing wrapper
for gdal:warp. It takes the argument TARGET_EXTENT, and uses that for the
GDAL arg "-te". However, it then tries to add in extent details, and I think
there might be an incorrect variable name. In warp.py from line 190:
arguments.append(rasterExtent.xMinimum())
arguments.append(rasterExtent.yMinimum())
arguments.append(rasterExtent.xMaximum())
arguments.append(rasterExtent.yMaximum())
I'm not sure "rasterExtents" is defined, but substituting the more plausible
"extent" gets no extent value out.
Is this an issue, or are the Python bindings for Processing's
gdal:warpreproject working for others?
Thanks
Tom
Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
