[QGIS-Developer] [Qgis-psc] Bringing back a *highly curated* blocker tag on redmine?
Daan Goedkoop dgoedkoop at gmx.net
Tue Jan 30 03:18:01 PST 2018
Hello Jürgen,
apparently the open bugs which are regressions and cause data
corruption or crashes are only 10 in number at the moment (of which I
reported one). I think they are important because they can catch you
by surprise in tested and established workflows. New things will
probably only be used heavily in serious contexts after some testing,
so I feel that problems there are not quite as important.
Kind regards,
Daan
2018-01-30 11:09 GMT+01:00 Jürgen E. Fischer <jef at norbit.de>:
> Hi Giovanni,
> On Tue, 30. Jan 2018 at 09:09:52 +0000, Giovanni Manghi wrote:
>> * a regression that causes data corruption
>> * a regression that causes qgis to crash
> I still don't understand this obsession with regressions ;)
> Any bug that is severe should block the release.  Whether it's a regression or
> not doesn't matter.
> If it's an unavoidable bug in some heavy used thing that is new, it's just as
> blocking as a big bug in known territory.
> IMHO a bug in some remote, hardly used function shouldn't block a release -
> even if it's a regression that corrupts data and causes qgis to crash in some
> edge cases.  We'll probably have plenty of those that we don't know of anyway.
> To me it's just a matter of the impact on usablity a bug has.  I'd opt for
> common sense instead of setting strict rules.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden             http://www.norbit.de
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
