[QGIS-Developer] build fails
Patrick Dunford enzedrailmaps at gmail.com
Wed Jul 4 22:46:59 PDT 2018
There are packages for bionic if that is what you are building on.
On 05/07/18 13:03, Donald Harter wrote:
> I fetched and pulled the latest source code for Qgis and it does not
> build. Is there some sort of new dependency?  My distribution does not
> have such a package.
> -- Qt WebKit support enabled
> CMake Error at CMakeLists.txt:303 (FIND_PACKAGE):
>   By not providing "FindQt5SerialPort.cmake" in CMAKE_MODULE_PATH this
>   project has asked CMake to find a package configuration file
> provided by
>   "Qt5SerialPort", but CMake did not find one.
>   Could not find a package configuration file provided by "Qt5SerialPort"
>   with any of the following names:
>     Qt5SerialPortConfig.cmake
>     qt5serialport-config.cmake
>   Add the installation prefix of "Qt5SerialPort" to CMAKE_PREFIX_PATH
> or set
>   "Qt5SerialPort_DIR" to a directory containing one of the above
> files.  If
>   "Qt5SerialPort" provides a separate development package or SDK, be
> sure it
>   has been installed.
> -- Configuring incomplete, errors occurred!
> Distributor ID:    Ubuntu
> Description:    Ubuntu 18.04 LTS
> Release:    18.04
> Codename:    bionic
> git branch
> * master
>   release-3_0
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
